Posted: 2020-07-04 01:52 AM . Last Modified: 2024-04-05 04:00 AM
Kindly i have a customer that need a solution for activating a Becon/Siren in the case of any "Critical" category Alarms from DCE.
Project Details as below;
(any "Critical" Category alarm from these devices must initiate a Becon/Siren)
I've tried another solution >> PC connected to high volume speaker to get sound notification whenever there is an alarm in the devices, as below;
Unfortunately, the drawback of this way is that the Alarm sound will not differentiate the Critical Alarm category (i.e: sound will play in case of any alarm), also, the sound will be played once (while we need it to be played continuously until the Alarm is cleared).
BR
(CID:126175739)
Hi Momen Samy,
DCE has only that one option to play a sound and the client must be running on a computer for the sound to be heard. There is sadly no alternative configuration for this option.
I can add this as an enhancement request (you can too under the resources menu) however I can't say when the feature will make it into the system if at all.
Steve
(CID:126175915)
Posted: 2020-07-04 01:52 AM . Last Modified: 2023-10-20 05:03 AM
