BCM re-associating in DCO after DCE deletion and rediscovery
  • EcoStruxure IT forum
  • BCM re-associating in DCO after DCE deletion and rediscovery
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-06 12:05 AM . Last Modified: ‎2024-04-02 11:42 PM
790
I deleted a modbus device in DCE and rediscovered it. This BCM device was associated with a floor PDU in DCO.
After rediscovering, and reassociating in DCO (due to a DDF issue), DCO shows a "recommendation" that associated device data has been lost. Of course it has and I understand that, but I cannot get this recommendation to clear. Will it go away on its own after a time period? There are no longer any offline associated devices with this floor PDU.
Thanks!
(CID:152569196)
  • Data Center Operation
Replies 4
790
Hello Jeff.
Did someone go to the BCM device entry in the DCO navigation view and clear the lost association?
Regards
Greg Sterling
(CID:152569881)
I'll check. I didn't see a lost association under "discovered devices" but if its only visible in the navigation view, I didn't do that. I will do that and mark this answered when I figure it out. I will make an attempt tomorrow Thursday 12/12/19 when I'm next logged into that customer environment.
(CID:152569883)
All set, thank you!
(CID:152569885)
Posted: ‎2020-07-06 12:05 AM . Last Modified: ‎2023-10-20 05:02 AM
