Can ITOptimize discover guest servers in HyperV
  • Can ITOptimize discover guest servers in HyperV
127
Posted: ‎2020-07-06 12:04 AM . Last Modified: ‎2024-04-02 11:42 PM
1327
Dear Team,
Kindly can ITOptimize discover guest servers in HyperV be it Linux, unix or Microsoft?
Thank you.
Regards.
(CID:152569012)
  • Data Center Operation
  • IT Optimize
1327
Hello Mashwiz
I'm sorry to say IT Optimize does not have an integration with Hyper-V so it is unable to discover Hyper-V guests. Guest discovery is limited to VMware hosts.
Regards
Greg Sterling
(CID:152569431)
Replies 4
1328
Hello Mashwiz
Regards
Greg Sterling
(CID:152569431)
Posted: ‎2020-07-06 12:05 AM . Last Modified: ‎2024-04-02 11:42 PM
Hi Greg,
Thank you for your response.
Can it discover the host with the Hyper-V?
Regards.
(CID:152569616)
In this case you're referring to the actual hyper-v server? Yes, that should be discoverable using the WMI protocol and credentials.
Regards
Greg Sterling
(CID:152569618)
Posted: ‎2020-07-06 12:05 AM . Last Modified: ‎2023-10-20 05:05 AM
