Posted: 2020-07-05 01:46 PM . Last Modified: 2024-04-04 12:24 AM
Hi Support,
We have a customer who has lost their root password to DCO 8.1, and is attempting to reset it as per the instructions detailed here:
However the console is responding with the message:
passwd: Authentication token manipulation error
Could you assist?
(CID:134694220)
Hi David,
I have moment ago tested the instructions (Resetting user password on the DCO server) to change my user password on DCO without any problem. Here is a screen shot to illustrate what I've typed and also confirmation that the password change was successful:
Kind regards
(CID:134694330)
Posted: 2020-07-05 01:46 PM . Last Modified: 2024-04-04 12:23 AM
Hi Jef,
Thanks for looking. The below is the error that is coming up on attempted reset:
(CID:134694401)
Hi David,
As far as I know, due to security "root" log in has been disabled (many many versions ago). I think even during the software installation it is instructed to not use root as log in name.
Kind regards
(CID:134694417)
Posted: 2020-07-05 01:47 PM . Last Modified: 2024-04-04 12:23 AM
Thanks Jef. I guess they probably have the wrong username also.
David
(CID:134694475)
Posted: 2020-07-05 01:47 PM . Last Modified: 2023-10-20 05:01 AM
