Ap7721 - Genomes
  • EcoStruxure IT forum
  • Ap7721 - Genomes
124
110
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 02:06 AM . Last Modified: ‎2024-04-09 12:23 AM
849
Ap7721 - Genomes
Hi
Could someone explain me how to connect the power of an ATS (Ap7721).
The genomes have no Input or Output plug.....
Tks
Best regards
Rocchino
(CID:105471604)
  • Data Center Operation
  • Genome
Replies 7
849
Hi Rocchino,
Currently the rack mounted ATS (such as ap7721) is not supported in DCO,  but stand alone ATS (floor equipment) would be supported.
As a work around you might want to use/customize for example a "Generic ATS" and place it next/behind the rack.
Kind regards
(CID:105471645)
Hi Jef tks but I really need to use in DCO Ap7721 becaus in my racks I have 2 Pdus and mono equipments connected on the Ap7721 which is connected on the two pdus. The work around would be to use a Generix Pdu with 2 power input.... Best regards Rocchino
(CID:105471647)
Posted: ‎2020-07-03 02:07 AM . Last Modified: ‎2024-04-09 12:23 AM
Hi Rocchino, I believe we have a similar feature request in our system, I will go ahead and add you to the existing case. Kind regards
(CID:105471669)
Hi Jef TKS. Have a nice day Kind regards Rocchino
(CID:105472072)
Howdy Jef,
This would be great to have a correct model, either ap7721 or ap7723 or the ap7724 so that the functionality of DCO capacity shows a correct power utilisation and power path.
Thanks Guys, and please add myself to this existing case.
Sadly someone closed mine but without notification to me.
Kind Regards,
Matthew
(CID:123342575)
Hi Matthew,
Many thanks for the comments, it is now added to the existing feature request case. I will send you a direct email shortly.
I'm not sure I understand what you mean by "Sadly someone closed mine but without notification to me." ? Thanks.
Kind regards
(CID:123342834)
Posted: ‎2020-07-03 02:07 AM . Last Modified: ‎2023-10-31 10:15 PM
