Alarm display in DCE Web page
  • EcoStruxure IT forum
  • Alarm display in DCE Web page
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-06 01:08 AM . Last Modified: ‎2024-04-02 11:19 PM
1800
I update DCE to 7.7.1
Since that, the alarm canot be seen in dce web page with EDGE or IE. Works fine with chrome.
Is there a solution for this problem?
 with Edge
with chrome
(CID:153945316)
  • bug
Replies 9
1799
Dear INFRABEL ICT,
I can recommend you update DCE software to the latest version 7.8.0.
If this bug is not fixed in the latest version, then you need to open the support case in =SE=. To do this, you need to contact the =SE= local support service in your region/country.
Hope this helps you.
With respect.
(CID:153945327)
Hi spezialist,
Please do not reply if you don't know.
The bug is also there in 7.8.0
This community is the right place to report bugs.
(CID:153945370)
Posted: ‎2020-07-06 01:09 AM . Last Modified: ‎2024-04-02 11:19 PM
Dear Everard Eduard,
From your comments:
Nevertheless, for the real bug fixes, it is necessary not only to create bug reports here on DCIM Community, but to create support cases =SE=. See, for example, only a small part of my posts here:
  • https://community.ecostruxureit.com/questions/152569614/dce-7.8.0-unknown-device-alarms-group-for-ma...
  • https://community.ecostruxureit.com/questions/152078265/dce-7.8.0-russian-letters-с-and-я-are-displa....
  • https://community.ecostruxureit.com/questions/148772130/dce-7.7.1-client-menu-change-server-does-not...
  • https://community.ecostruxureit.com/questions/148771781/dce-7.7.1-no-sensor-history-available-to-dis...
Therefore, I recommended INFRABEL ICT to first check for the presence of the above bug in the latest version of DCE. Secondly, I recommended creating an appropriate support case in =SE=.
I think this is the right approach to start solving this bug.
With respect.
(CID:153945427)
1799
I've entered a report on this issue. I was able to replicate on IE with version 7.8.
Chrome looks fine.
I don't have Edge but since I'm seeing it on IE, I'll assume Edge is the same.
All I can suggest for now is to use Chrome until this issue is resolved.
Steve
(CID:153945458)
Ok, thanks for the report on this issue.
Regarding Microsoft Edge, which recently migrated to the new Chromium platform (https://support.microsoft.com/en-us/help/4501095/download-the-new-microsoft-edge-based-on-chromium😞 I tested and I can confirm, that this bug does not appear (Microsoft Edge based on Chromium - Version 79.0.309.71 Official build 64-bit).
With respect.
(CID:153945506)
Thanks for updating. I've updated the report on this issue as well.
Steve
(CID:154404380)
1799
I update to the last version of edge ant it works.
Regards
(CID:154403920)
Ok, very thanks for the good feedback 😀.
(CID:154403924)
Posted: ‎2020-07-06 01:09 AM . Last Modified: ‎2023-10-20 05:00 AM
