Posted: 2020-07-03 01:26 AM . Last Modified: 2024-04-09 12:36 AM
I had a custom DDF created. Is there a way to add items for the "Alarm Configuration" tab in DCE? So I can alarm on the custom points in the DDF?
(CID:105469716)
Hi John,
You can right click a device and choose the create thresholds option. Once you've found the sensor and set the threshold value, this threshold should show up on the "Alarm Configuration" perspective under "Threshold Alarm Configurations" along with the default "Communications Status" alarm. They can then be individually added to any notification policy you choose.
Steve
(CID:105469718)
Hi John,
Steve
(CID:105469718)
Thank you!
(CID:105469723)
Posted: 2020-07-03 01:26 AM . Last Modified: 2023-10-31 10:14 PM
