Posted: 2020-07-03 03:44 AM . Last Modified: 2024-04-08 11:53 PM
Dear Team,
We used to have Air flow sensor for the discontinued NetBotz 500, do we have the same for NBRK0450 & NBRK0570?
Thank you.
Felix.
(CID:106207439)
The appliance Netbotz 455 also have the Air Flow Sensor on board.
(CID:106207446)
Hi Felix!
You can use Sensor Pod 120 connected via USB or Room Sensor Pod 155, connected via A-Link to 450 and 570 appliances.
Each of them have airflow sensor on board.
(CID:106207441)
Hi Valentin, Thank you for your response. I shall try the sensor pod 155 as the 120 is discontinued. Regards, Felix.
(CID:106207443)
(CID:106207446)
Posted: 2020-07-03 03:44 AM . Last Modified: 2023-10-31 10:14 PM
