Posted: 2020-07-03 11:22 PM . Last Modified: 2024-04-05 04:57 AM
How is it possible to map power paths to RM UPS please? There seems to be no "power" options on genome properties.
Example attached:
2x RM UPS in separate racks
(in this case APC Smart-UPS SRT 8000VA 230V / p# SRT8KRMXLI)
UPS-A feed PDU-A in rack 1 & rack 2
UPS-B feed PDU-B in rack 1 & rack 2
Cheers
Fletch 😀
(CID:124527715)
Sadly not supported. Please add your name to the feature request list. If the functionality is critical and u can tolerate a work around, consider using dummy floor mount UPSs and maybe blanking panels in rack to represent the rack mount UPS
(CID:124527866)
Hello guys,
I am facing the same question at the moment: if there the possibility is to connect rack mountable UPS to the power path?
So, are there any updates in this case, and what is the best solution at the moment? If I use the floormount UPS, can I somehow hide it? Or can I somehow put rack on the floormount UPS or under it?
Janis
(CID:128754630)
Posted: 2020-07-03 11:22 PM . Last Modified: 2023-10-20 04:59 AM
