Adding markers in SE Help, SE Login and Classic themes
  • Adding markers in SE Help, SE Login and Classic themes
126
65
Posted: ‎2020-07-05 07:44 PM . Last Modified: ‎2024-04-03 02:33 AM
1020
i'm not able to add markers for the location map portlet on such themes. Anyone knows why? Is there a way to do such thing?
Regards
(CID:144312568)
  • Portal
Replies 5
Posted: ‎2020-07-05 07:45 PM . Last Modified: ‎2024-04-03 02:33 AM
1020
Hi Javier,
I think the SE specific portlets are designed to work with SE Theme - it is recommended only to use the SE theme with the SE specific portlets.
Kind regards
(CID:144312935)
oh... and there's no way to emulate, for example, the borderless portlets that exists in SE themes on the non-SE ones?
(CID:144313149)
Posted: ‎2020-07-05 07:45 PM . Last Modified: ‎2024-04-03 02:32 AM
I mean, not putting that portlets but modifying the existing ones to make them borderless.
(CID:144313150)
Well it seems that for some reason I'm not able to get Liferay's page access through Portal and maybe that's the reason the Schneider's portlets won't show up information in Liferay's themes.
Any clue about this? Could I need some extra permissions to enable Schneider's portlets information in Liferay's themes?
Regards!
(CID:144313156)
Posted: ‎2020-07-05 07:45 PM . Last Modified: ‎2023-10-20 04:59 AM
