Adding LAN2 on virtual DCE?
  • EcoStruxure IT forum
  • Adding LAN2 on virtual DCE?
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 01:14 PM . Last Modified: ‎2024-04-09 04:37 AM
640
I have added an additional virtual network card to DCE but it is not visible in the network settings screen.
What else do i need to do to get the LAN2 (private) to show up?
I need the second LAN to receive SNMP traps...
(CID:97485671)
640
Hi Chad,
Did you follow the documentation for adding the second adapter on page 3-4 of the below manual?
http://www.apcmedia.com/salestools/JLER-8M7NG2/JLER-8M7NG2_R4_EN.pdf
If so, do you see any errors on the boot up sequence when you restart the virtual DCE? Can you send a screenshot if there are any errors please?
What version of DCE are you currently using?
Is this a new deployment of the DCE or do you have it up and running for a while?
Breda
(CID:97485684)
641
Hi Chad,
Breda
(CID:97485684)
Thanks, that fixed it. I hadn't seen that document on any of my searches...
(CID:97485750)
Posted: ‎2020-07-02 01:14 PM . Last Modified: ‎2023-10-31 10:13 PM
