Add recordind task to Work Order Tempalte
  • Add recordind task to Work Order Tempalte
129
72
Posted: ‎2020-07-04 09:46 PM . Last Modified: ‎2024-04-04 03:33 AM
1309
Hello
We are using DCO 8.2.2 .
I didn't find create template of the work orders , instead of this there is work orders process  or work order empty .
When I create WO from work orders process there is alert ,  that I can't add any activity tasks to this WO .
My goal :
1.
Create template of the work order that content a few returns tasks .
Create WO from this template and add recording task (for example add server to rack, create connectivity or add task  manually) .
2
How I create  automatically task that can added to WO with action .(like add task connect server to PDU when I add server to rack) ?
For example add server to rack – the task "Set labeling to this server" added by automatically like connect to PDU .
Many thanks in advance
(CID:133371918)
  • Data Center Operation
1309
Hi Boris,
Working and creating work orders and work order process described in the following pages:
Creating and applying work order processes
Working with work orders
In general, tasks  can be used as template (as process) but not operations like adding certain hardware/server, connecting to pdu's etc.
Kind regards
(CID:133373297)
Replies 8
Hello
Who is  working with Work Order ?
Can I create Work Order process and add recording task  ?
(CID:133373289)
1310
Hi Boris,
Kind regards
(CID:133373297)
Hello Jef .
Many thanks on your explanation .
On demo server I found the work order process that I can add recording/manually   task (like placeholder ) .
Also there are work order process that I can't add recording/operation task
How I can create work order process like placeholder ?
(CID:133373671)
What is different between it's too work order tasks ?
(CID:133373677)
Hi Boris,
In your demo example, when you apply the work order process "Move server" it may initially contain two tasks: 'Back up data' and 'Notify users', and then additional user defined tasks (non operational) can be added.
However, when you apply the work order process "Process with placeholder" (contains work order recording task), then you will have a define work order flow: "Before" -> "Work order recording" -> "After", in this work order you can add both user defined tasks and also operational works such as moving the device/server, adding new device, etc.
Kind regards
(CID:133374290)
many thanks
I have found the WO flow according to your link that you sent in last comments.
It's very help to us and our customer .
Many thanks
(CID:133374738)
You are most welcome, Boris
Sounds great that it helped.
Kind regards
(CID:133374794)
Posted: ‎2020-07-04 09:46 PM . Last Modified: ‎2023-10-20 04:58 AM
