Access Building Operation Webstation through Cisco ASA SSLVPN
  • Access Building Operation Webstation through Cisco ASA SSLVPN
129
72
Posted: ‎2020-07-05 02:26 PM . Last Modified: ‎2024-04-03 11:54 PM
1133
Greetings! I am seeing some weird behavior trying to get Building Operation Webstation working through an SSLVPN - hopefully somebody has seen this before.
The auth page for this web-service loads / works just fine when I browse to it from within the LAN. The page also loads / works fine when traversing from the Internet (via static nat mapping).
Interestingly, while I have been able to get my other web-pages / services working through the SSLVPN, this one particular service is giving me fits.
When successfully loaded auth-landing-page should look like this.
What I am seeing is this
Ideas?
(CID:136644859)
  • Portal
  • bug
Dear Atom Snine,
Your question is best to ask on the right resource, that is Building Management WebHelp. There you can get the right answer to your question.
With respect.
(CID:137103092)
Dear Atom Snine,
With respect.
(CID:137103092)
Posted: ‎2020-07-05 02:26 PM . Last Modified: ‎2023-10-20 04:58 AM
