Posted: 2020-07-04 12:52 AM . Last Modified: 2024-04-05 04:26 AM
Attempting firmware upgrade v3.9.2 for ATS model AP7730. StruxureWare DCE displays the following damage notice when clicking on apply update. Currently source A is used to power devices. Any known issues unplugging the secondary (source B) for this model at FW v3.5.6 (app) / v3.5.7 (AOS).
Current ATS Status
(CID:126165709)
Posted: 2020-07-04 12:52 AM . Last Modified: 2024-04-05 04:25 AM
Hi Barry Patterson,
And what is your question?
Is it possible to you to perform the Rack ATS firmware update without disconnecting the secondary source (as was noticed DCE-server)?
Probably there is some sense in this, and it is better to follow this recommendation.
More details about this problem, I highly recommend reading in topic , especially the answers of Balaraman Jagadeesan and Angela Clark.
P.S.: But in practice I performed exactly the same procedure for updating the firmware as you (to the final version 3.9.2) have about a hundred Rack ATS without disconnecting the secondary source. And for all this time there was not a single case of loss of power to equipment or damage the Rack ATS.
I repeat: this is my experience and my opinion.
With respect.
(CID:126165936)
Hi Barry Patterson,
You have successfully solved your question or not?
With respect.
(CID:126167540)
Posted: 2020-07-04 12:52 AM . Last Modified: 2023-10-20 04:57 AM
