Posted: 2022-06-16 01:14 AM
Can I get the current power usage per Machine/cabinet, etc. with API?
Posted: 2022-06-16 04:37 AM
Hello, is this an IT Advisor question?
ITA's REST api can return MEASURED_PEAK_LOAD per power device (like a PDU or Rack PDU) and items like a rack of course assuming the device has measured data.
A sample API call would look like this... where you'd substitute your server IP or hostname for "<ITA-Server>" and the asset UUID for "<AssetID>"
https://<ITA-Server>/api/v8.1/kpis/latest?asset-id=<AssetID>&type=MEASURED_PEAK_LOAD
Regards
Greg Sterling
Regards
Greg Sterling
Posted: 2022-06-19 01:08 AM
it's returned values only when I took the roomId as AssetID, but when I take 'id' of the host it returns an empty answer
In detail, when I run:
(1) https://132.76.78.41/api/v8.1/assets/search?q=cn100
take the id and put it as AssetID in
(2)https://132.76.78.41/api/v8.1/kpis/latest?asset-id=7a63...&type=MEASURED_PEAK_LOAD
get nothing.
if I take from first command the roomId and put it as AssetID in the second command I get detalis
Is it working with is or only with roomid?
Posted: 2022-06-20 05:37 AM
What type of device is cn100?
Power KPI data is not kept of all device types as only some are capable of reporting it.
Regards
Greg Sterling
Posted: 2022-06-20 11:37 PM
cn100 is a server in the output of the api is:
"type": "blade",
Thanks.
Posted: 2025-02-25 02:01 PM
How can one locate a type of a device using just IP via an API? I do not have GUID for thousands of devices and need to check the details like Type and Location in SW, for a report. Is there an API or efficient way that I could use which doesn't use GUID to get a device type and details?
