Posted: 2020-07-05 08:30 PM . Last Modified: 2024-04-03 01:12 AM
Hello there,
Is there an API set to manage network cable connections? We could not find any related APIs on the swagger API Documentation for network cable connection or I missed reading the documentation.
If the APIs still do not exist, is there any plan to provide the API for network cable connections on the roadmap?
I will highly appreciate for some responses.
Thank you.
(CID:146671034)
Hi Bayu,
Currently there is no REST API to mange network cable connections.
However, one of near future plan item is to build the network connection feature in the web-client. I guess during that process REST APIs may also be revisited (but no promises at this point), thanks.
Kind regards
(CID:146671081)
Hi Bayu,
Kind regards
(CID:146671081)
Okay. Thank you for your reply.
Good move. I think, when the network connection feature on web-client is being built, at least API to GET the related items with its ports and from-to connection pair list has to be created as well. I hope the GET API will be soon published even with Internal state.
Soon after that, please provide us the API to create/save network cable connections between assets/devices.
Thank you.
(CID:147194038)
Posted: 2020-07-05 08:30 PM . Last Modified: 2023-10-20 04:57 AM
