Posted: 2020-07-02 10:02 AM . Last Modified: 2024-04-10 01:02 AM
Hi Team,
Kindly, do the above subject sensor still exist? if they do, can I use them for sensing power loss at each subsystem for clients who do not have intelligent power equipment and equally do not wish to replace them any time soon.
Felix
(CID:93913786)
Hi Felix,
Do you want to use this sensor with a v2 or v3 Netbotz appliance? If it is a v2 appliance it can be connected directly or if its a v3 Netbotz appliance (570, 450 etc), then you would need a version 2 sensor pod which will work with the v3 Netbotz appliance, that has USB capabilities. We don't sell the amp detector on the website anymore but it can possibility be gotten from a reseller. The SKU is NBDA30L2.
Maybe the best option is to invest in a 3rd party amp detector which either uses 0-5 volts or 4-20mA. I don't have an officially tested amp detector to recommend.
Breda
(CID:93913822)
Hi Breda,
I am using it with a v3 NetBotz.
Well noted, thank you.
Felix.
(CID:93913831)
Posted: 2020-07-02 10:02 AM . Last Modified: 2023-10-31 10:16 PM
