Posted: 2020-07-05 04:55 PM . Last Modified: 2024-04-03 04:20 AM
Could you please confirm if this licenses, AP951000, have a limited time of use or are perpetual?
Thanks in advance.
(CID:139693054)
Posted: 2020-07-05 04:55 PM . Last Modified: 2024-04-03 04:19 AM
Hi Kamal,
AP951000 is a StruxureWare Data Center Expert 1000 node license. It is a permanent license key and has no time limitation. There are instances where customers may work with our sales teams, usually with smaller licenses, where a temporary key can be created for testing purposes but you'd need to speak with your local sales/support people for that.
Steve
(CID:139693059)
Hi Kamal,
Steve
(CID:139693059)
Many thanks Steve for your quick and clear answer.
Regards
(CID:139693074)
Kamal,
Just as an FYI, the AP951000 is a device node license, of which require software support to receive upgrades and technical support.
1 Year Support: WMS1YR1000N
3 Year Support: WMS3YR1000N
Support is also required on any other devices node licenses installed on the Data Center Expert system (base 25 nodes covered by base software support SKU)
Kind Regards,
Cory
(CID:139693076)
Very Clear Cory. Many thanks.
(CID:140217470)
Posted: 2020-07-05 04:56 PM . Last Modified: 2023-10-20 04:56 AM
