AP9475 Hardware Specifications
  • AP9475 Hardware Specifications
129
72
Posted: ‎2020-07-05 05:47 PM . Last Modified: ‎2024-04-03 03:14 AM
896
Could you please share with me the DCE Enterprise server current specifications. What PowerEdge server model is being use? My client would like to verify the hardware specifications.
(CID:140712173)
Hi Kevin,
Dell PowerEdge R730 which is I believe the most recent server to be used for the AP9475. I do have an R730 which using the Dell service tag, I checked the config for that server. I've attached a file containing the info about the system. If they have one of our servers, they can do so as well.
OEMRXLR730_Components.csv
Steve.
(CID:140712718)
Hi Kevin,
Steve.
(CID:140712718)
Posted: ‎2020-07-05 05:47 PM . Last Modified: ‎2023-10-20 04:55 AM
