Posted: 2020-07-05 03:43 PM . Last Modified: 2024-04-03 11:20 PM
do you know where can i get the full mib for the ACRD602P
the mib in the Schneider Electric site is not full it is misse tie alarms !
(CID:137728211)
Dear Yaniv,
You can access ACRD602P Management Information Base details in the below link.
https://www.apc.com/salestools/SJAN-AJRUEW/SJAN-AJRUEW_R0_EN.pdf
As mentioned in the document, ACRD602P uses Powernet MIB which can be downloaded in the below link.
https://www.apc.com/in/en/tools/download/
I hope this helps.
Bala
(CID:137728303)
Hi Bala
If you open the PDF you can see that
there is no Alarms OID
do you have the full Alarms OID for the unit ?
Yaniv
(CID:137730350)
Yaniv Rozenbaum Hi Yaniv, I hope you are doing well. The most recent Powernet MIB version is 4.2.8 that can be downloaded from
I also attached powernet428 file to this post here. powernet428.mib
If you have an access to the NMC card of this unit via SNMP, I suggest you to use any SNMP MIB browser such as iReasoning and try doing an SNMP walk and see if you are able to locate the SNMP OIDs for the alarms or status of the unit. I am sorry that I do not have an access to the unit online, and therefore I can not verify it. But, Powernet MIB is the one that ACRD602P Uses.
Bala
(CID:137730381)
Dear Yaniv Rozenbaum,
Please tell us if you could solve your question or not?
With respect.
(CID:137729827)
Posted: 2020-07-05 03:43 PM . Last Modified: 2023-10-20 04:54 AM
