Posted: 2020-07-03 02:24 AM . Last Modified: 2024-04-09 12:18 AM
Hi Everyone;
I need DDF file for ABB G13 Gateway,
(CID:106202924)
Hi Alper,
You can get a DDF or get one created by either choosing the "Add My Device" option at the top of the page or by e-mailing multivendorsupport@apcc.com. That being said, you usually do not get a DDF for a gateway. The gateway is normally a simple translator for a modbus serial device residing on the other side of that gateway. Although I'm not familiar with the gateway you suggest, it would usually be that device that would require a DDF. Also, the gateway in question has not been officially tested so unless someone else on the forum has any experience with it, I can say that any gateway should work but we can't guarantee it.
Steve
(CID:106202961)
Hi Alper,
Steve
(CID:106202961)
Posted: 2020-07-03 02:24 AM . Last Modified: 2023-10-31 10:12 PM
