Posted: 2020-07-03 12:24 AM . Last Modified: 2024-04-09 12:56 AM
we have a 4 panel main room pdu and can add sensor mapping to 2 of those panels, but not to 2 x others and can't understand why. Other multiple panel pdu's can have sensor mapping without any issues.
(CID:105466877)
Hi all,
Just a small note that this is/will be investigated off-line.
Kind regards
(CID:105467796)
Hi Pete It should of course work for all PDUs, but it is difficult to see what is the issue without more information. Do you have a screenshot of the setup that you can share? That would be a start to try and reproduce the issue. Best, Niels
(CID:105466886)
Hi all,
Kind regards
(CID:105467796)
Hi all, In short, customized DDF file did fix the issue, so the device could be associated to its corresponding model in DCO. Kind regards
(CID:105469538)
Posted: 2020-07-03 12:25 AM . Last Modified: 2023-10-31 10:12 PM
