Posted: 2020-07-02 11:43 AM . Last Modified: 2024-04-10 12:07 AM
Dear Team,
I am facing a problem in DCE 7.2.6 I have 3rd party rack PDU (Raritan PX2-2530) it is giving error when I open in DCE internal browser, on external browser it is working fine, kindly see the attached screenshots.
Rana
(CID:95355754)
Hi Rana,
Please try changing the device launch setting available in the Right click Menu of the device.
Let us know if it doesn't help.
(CID:95355767)
Hi Deshmukh, I already use the same setting.
(CID:95355775)
Posted: 2020-07-02 11:43 AM . Last Modified: 2024-04-10 12:06 AM
We just started using PX2-4397 in our environment and I am configuring them now. You have to connect via HTTPS but it still will not pass the UN/PW along. I'm also having trouble with SNMP and not seeing any sensors.
(CID:101027935)
Hi Rana, Looking at your screenshots it is not the same device that is opened in the external browser .224 and trying to be opened in the internal one .204 (as I see it) I'm pretty sure that it is also failing for .224 in the internal browser just wanted to be sure. Some more information regarding the internal browser and also using an external as alternative can be found here: http://dcimsupport.apc.com/display/UADCE725/Browser+Settings Some more information regarding the "Device launch settings" is found here: http://dcimsupport.apc.com/pages/viewpage.action?pageId=92078296 A similar subject regarding number of tabs in the internal browser has also been discussed earlier: http://dcimsupport.apc.com/questions/93915320
(CID:96043019)
Dear Rana Ajmal
Once again Follow the
Raritan Installation Manual.
http://support.raritan.com/px2/version-3.0.0/quick-setup-guides/QSG-DPX2-0L-v3.0-E.pdf
(CID:101613704)
Posted: 2020-07-02 11:44 AM . Last Modified: 2023-10-31 10:12 PM
