ITO: Additional information from discovered servers?
  • ITO: Additional information from discovered servers?
128
Posted: ‎2020-07-02 08:43 AM . Last Modified: ‎2024-04-10 01:25 AM
948
When we discover a server with ITO we can see the number of processors. Is there a way the get information about the number of CPU cores and the amount of memory (RAM)?
The information would be useful in the cases where we need to verify that we have the correct software license on the server (some software are based on number of cores and/or amount of memory).
(CID:90898938)
  • Data Center Operation
  • IT Optimize
947
Hi Christian,
At present it is not possible to get this type of information from the IT Optimize module.
As you state the number of processors is available.
It is possible to get memory information as well from MS SCOM integration. The data is presented in DCO in discovered devices and equipment browser.
(CID:90899052)
Replies 5
Hi Christian, we will look into it, thanks for posting.
(CID:90898972)
948
Hi Christian,
(CID:90899052)
Isn't the amount of CPUs and memory part of the genome?
(CID:92539611)
The amount of CPUs and memory is not available from the genome without discovering the device using one of the described integrations.
(CID:93192236)
Posted: ‎2020-07-02 08:43 AM . Last Modified: ‎2023-10-31 11:19 PM
