pick action error on redundant system
  • Remote Operations
  • pick action error on redundant system
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
116
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
PATRUCK
PATRUCK
Cadet
Posted: ‎2022-11-18 11:49 AM . Last Modified: ‎2023-05-02 11:50 PM
1158
Customer has system with redundant setpt and in one building the pick action for a switch works but in the other building when you select the object they get the following error message
error at column`1 of pick action code Unknown error 0x80072fd
They are use a script for the pick action
Mode
Excute Code Fragement
Code
Server.SetOPCValue "PUMP_AUTO_CSS",0
Server.SetOPCValue "PUMP_REQ_CSS",1
Not sure where to go to fix this. would think this would be a OPC issue since not linking to the oter system.  but did not set this system up so not sure where i need to go resolve it.
Patrick
patrick@batelectric.net
Bast Electric
  • Scripting
AndrewScott
Admiral AndrewScott
Admiral
Posted: ‎2022-11-21 01:51 AM
Windows HRESULT's have 8 hex digits, but 0x80072fd only has 7 digits, so it would appear to be truncated (missing last digit?).
What is meant by it works in one building but not the other? Is this referring to which server is main? Is this referring to which server the client is connected to? Is this referring to which client is being used?
Andrew Scott, R&D Principal Technologist, AVEVA
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
geoffpatton
Captain geoffpatton
Captain
Posted: ‎2022-11-21 10:36 AM
Maybe the issue with TLS mention by @bamador a few replies down.
https://community.se.com/t5/EcoStruxure-Geo-SCADA-Expert/Unknown-error-when-addressing-a-point-in-sc...
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
