getDescendants .NET API
  • Remote Operations
  • getDescendants .NET API
sbeadle
Kirk sbeadle Kirk
319
AndrewScott
Admiral AndrewScott
114
BevanWeiss
Spock BevanWeiss
97
AdamWoodlandToo
Lt. Commander AdamWoodlandToo
39
EcoStruxure™ Geo SCADA Expert
IvanDeMarco97
Lieutenant JG IvanDeMarco97 Lieutenant JG
Lieutenant JG
Posted: ‎2024-04-15 06:50 AM
740
Hi everyone,
I'm using this method "obj.GetDescendants("CGroup, "")" but if there are more than 10000 items it doesn't work ('Limit of 10000 objects for ListObjects reached. Specify a filter to reduce the number of objects returned.'). How can I write an alternative function that returns me the same result?
  • SCADA
  • Scripting
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2024-04-16 12:30 AM
I recommend using .GetChildren instead, to get direct descendants. Then recursively call it on any children which are groups/instances/templates.
AdamWoodlandToo
Lt. Commander
Posted: ‎2024-04-15 06:24 PM
Could use SQL, either through standard ODBC or via the .NET API.
Steve posted an example of via the .NET API at https://community.se.com/t5/EcoStruxure-Geo-SCADA-Expert/NET-API-to-query-ClearSCADA-View/m-p/200560
sbeadle
Kirk sbeadle Kirk
Kirk
