Posted: 2025-03-12 10:22 AM
Hi there,
When using the Pick Action Wizard -> Hyperlink functionality, there is a checkbox for opening up the hyperlink inside ViewX as tab. When linking to a web site (as opposed to another mimic) this results in an HTML tab created inside ViewX.
PickActionWizard Hyperlink Method
I am interested in passing data from a ViewX session to the hyperlinked URL via URL params (e.g "http:localhost:9999/app?param1=value1". Using the Pick Action Wizard->Hyperlink method, you don't have the ability to dynamically create the URL to do this.
Instead, you must use a script utilizing the Mimic.Navigate function to dynamically create the URL like so:
sub OpenHyperlink()
'Example value from ViewX session
systemName = Mimic.SystemName
'Pack into a string argument
arg1 = "param1="+CStr(systemName)
'Create the URL string
url = "http://localhost:9999/app?" + arg1
'Pass string to Mimic.Navigate function
Mimic.Navigate(url)
end sub
The above code works as expected but opens the hyperlink in a standalone Browser instance.
Is there any way to tell the Mimic.Navigate script function to open the browser inside ViewX similar to the Pick Action Wizard functionality?
Posted: 2025-03-13 02:58 AM
You can animate the PickParam property - put the whole URL in that.
Posted: 2025-03-13 06:32 AM
Not sure why I didn't think of that, thanks Steve!
