ViewX Home button disabled on DMZ Standby
  • Remote Operations
  • ViewX Home button disabled on DMZ Standby
sbeadle
Kirk sbeadle Kirk
319
AndrewScott
Admiral AndrewScott
114
BevanWeiss
Spock BevanWeiss
98
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
tkswathik
Lieutenant JG tkswathik
Lieutenant JG
Posted: ‎2020-08-17 11:19 PM . Last Modified: ‎2023-05-03 12:12 AM
1961
I recently added a DMZ Standby server to our existing Hot-Standby server environment. ClearSCADA version is 2017 R3 (July 2019). When I login to the ViewX instance on a fully synced DMZ Standby server, the Home button on the ribbon is disabled. My user account has a home page assigned and this doesn't load automatically when I login.
However this is not the case when I login to the ViewX instance on the Main / Standby server (Not DMZ or Permanent Standby). The home button is enabled and the home page on my account loads without any issues on these servers
When I login to WebX on the DMZ standby server (http://localhost) the home page loads without any issues.
I changed the server role from DMZ Standby to "Lone server", surprisingly ViewX doesn't have the issues I mentioned above and everything works perfectly. I find it hard to believe if the server role has something to do with this issue.
Has anyone had this issue before?
  • ViewX
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2020-08-18 06:18 AM . Last Modified: ‎2023-04-25 04:17 AM
1
1948
yes, this issue was found and has been fixed. The correction is available in the June 2020 Monthly Updates and beyond.
See: https://community.se.com/t5/Geo-SCADA-Knowledge-Base/Geo-SCADA-Expert-Downloads/ba-p/279116
Steve
sbeadle
Kirk sbeadle Kirk
Kirk
1
1949
Steve
tkswathik
Lieutenant JG
Posted: ‎2020-08-19 02:40 PM
In response to sbeadle
Thanks !!
