Using Embedded lists in templates
  • Remote Operations
  • Using Embedded lists in templates
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
116
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
krishnaprasad68
Ensign krishnaprasad68
Ensign
Posted: ‎2020-08-18 10:55 PM . Last Modified: ‎2023-05-03 12:11 AM
1556
I am trying to include Embedded lists in a SCADA template. When ever i try to include the SQL query as animation it is showing the following error...." The following tags are invalid: '%.Comms.Hreg.Input%' " .
The query iam trying to use is as folllows 'SELECT "FullName" AS "~FullName", "Id", "Foreground", "Blink", "Background", "TypeDesc", "MemoryUsage" FROM CDBPOINT WHERE "FullName" LIKE ''' + "%.Comms.Hreg.Input%" +''' '.
Can any one suggest where i am going wrong ?
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2020-08-20 05:06 AM
I think your % wildcards need to be in the string of the query:
'SELECT "FullName" AS "~FullName", "Id", "Foreground", "Blink", "Background", "TypeDesc", "MemoryUsage" FROM CDBPOINT WHERE "FullName" LIKE '%'' + ".Comms.Hreg.Input" +'%'' '
I can't tell if your animation property in the database ".Comms.Hreg.Input" is correct.
sbeadle
Kirk sbeadle Kirk
Kirk
