Posted: 2024-08-19 09:32 AM
I want to write some code to enter our historian path into the Historic Exports field, but I cannot find the the name of the field. I looked in the ServerObject help section to no avail. I have tried the following Node.Interface.HistoricExportIds , Node.Interface.Historic.Export and Node.Interface.Historic.Export.ID
Any help would be greatly appreciated.
Posted: 2024-08-21 01:47 AM
It is in the online schema:
| HistoricExportIds | Historic Exports | Array of Reference (CHistoricExport) |
Writing to an array is possible. Which API are you using?
You'll need to read the array first to check existing entries and avoid duplication.
See this C# .Net Client API code:
ClearScada.Client.Simple.DBObject PointObj = connection.GetObject("New Analog Point");
Aggregate hisagg = PointObj.Aggregates["Historic"];
int[] heids = (int[])hisagg["HistoricExportIds"];
// TODO - check you don't already have the new Id
int newAggregateId = 462970;
int[] newheids = new int [heids.Length + 1];
for( int i = 0; i < heids.Length; i++)
newheids[i] = heids[i];
newheids[heids.Length] = newAggregateId;
hisagg["HistoricExportIds"] = newheids;
I'm sure you could write better!
