Posted: 2025-04-13 03:32 AM
Hello everyone!
This is my Mimic:
This is my script (called by pick action):
Debug.....
Indeed: "Mimic.Parameters.Target" Object needed
Where am I going wrong?
Posted: 2025-04-22 11:45 PM
The example script states:
Set test = Mimic.Parameters
something = test.Point.CurrentValue
That parameter is now in your variable 'something'.
Posted: 2025-04-14 06:21 AM
Your Pictures are not showing. I would try different file formats or maybe lower resolution.
Posted: 2025-04-15 01:08 AM
I'm so sorry.
I'll try again: my Mimic
My code
Posted: 2025-04-15 10:18 AM
Interestingly your other picture are now showing.
I believe you need to put the "Mimic.Parameters.Target.FullName" in Quotes.
If it helps here is an example of where I have used FindObject with GetOPCValue. I think GetOPCValue is used so the code can work from a instance of a template.
Function SetPump2AlarmReset()
Dim objCTLcheck
Dim iResponse
Set objCTLcheck = Server.FindObject(Server.GetOPCValue("..IO.Config.Setpoints.Pump 2 Alarm Reset.FullName"))
If objCTLcheck.CheckAccess("CTL") = True Then
Server.SetOPCValue "..IO.Config.Setpoints.Pump 2 Alarm Reset.CurrentValue", 0
Else
iResponse = MsgBox("You do not have Control Privileges to Control " + Server.GetOPCValue("..Name") + "." , vbQuestion + vbOKCancel + vbDefaultButton2, "Station Control")
End If
End Function
I am not sure you are trying to get a database Object information though since I do not see anything in your database tree called Mimic.
Posted: 2025-04-16 01:54 AM
I would like to access the parameters defined for MIMIC as shown in this example
