Using ServerObject.Interface to read array-based properties
Select a Country
  • Remote Operations
  • Using ServerObject.Interface to read array-based properties
sbeadle
sbeadle Champion
335
AndrewScott
AndrewScott
125
BevanWeiss
BevanWeiss
103
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
rlao
rlao
Contributor
Posted: ‎2019-11-28 10:28 PM . Last Modified: ‎2023-05-03 12:20 AM
2899
Hi all,
Is it at all possible to read array-based properties using ServerObject.Interface in Scripting?
I am trying to read out the VectorValues property of a CProfileFloat profile object and populate a Form with the individual array values.
I can't get ServerObject.Interface to work at all as it complains about type mismatches.
I was doing something like:
Set FlowProfile = Server.FindObject(sFlowProfilePointFullName)
Vector1 = FlowProfile.Interface.VectorValues(0)
which did not work.
What is the correct way to do this?
  • SCADA
  • Scripting
AndrewScott
AndrewScott
Leader
Posted: ‎2019-11-29 01:33 AM
1
2886
The following JScript example works in a mimic script:
var Profile = Server.FindObject( "Time Profiles.Float" );
var Values = Profile.Interface.VectorValues;
var Times = Profile.Interface.VectorTimes;
var FirstValue = Values.getItem(0);
var FirstTime = Times.getItem(0);
I've not tried this from VBScript.
Andrew Scott, R&D Principal Technologist, AVEVA
BevanWeiss
BevanWeiss
Champion
Posted: ‎2019-11-28 11:26 PM . Last Modified: ‎2019-11-29 02:12 AM
@rlao works for me...
Dim scxServer As ScxV6Server
Set scxServer = New ScxV6Server
scxServer.Connect "Test", "superuser", "superusersuperuser"
Dim objDoubleArray As ScxV6Object
Set objDoubleArray = scxServer.FindObject("New Float")
Dim arrDoubleArray
arrDoubleArray = objDoubleArray.Property("VectorValues")
[apologies for bad variable names etc etc... definitely awkward having an array called 'arrDoubleArray' that is full of 'Singles' ;)]
AndrewScott
AndrewScott
Leader
1
2887
rlao
rlao
Contributor
Posted: ‎2019-11-29 03:15 AM
In response to AndrewScott
Hi Andrew,
I'm trying to do this in VBScript, but your reply actually helped me figure out what I was doing wrong.
Basically, in addition to what I was doing in my original post, I was also trying to read VectorValues out into a ReDim variable sized to the MaxVectors of the float profile. Turns out that doesn't work and the solution was actually much, much simpler than what I was trying to do.
It was more or less like your JScript answer:
Set FlowProfile = Server.FindObject(sFlowProfileFullName)
Dim FlowArray
FlowArray = FlowArray.Interface.VectorValues
Flow1 = FlowArray(0)
Flow2 = FlowArray(1)
Flow3 = FlowArray(2) etc...
Extremely simple and I can't believe it took me this long to figure out.
