[Imported] Alarm Count Query
  • Remote Operations
  • [Imported] Alarm Count Query
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
116
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2019-11-27 12:09 AM . Last Modified: ‎2023-05-03 12:20 AM
2256
>>Message imported from previous forum - Category:Scripts and Tips<<
User: Curious, originally posted: 2019-10-15 20:08:33 Id:560
I have a Point configured as an Alert Alarm. It has a redirection on it to escalate to a Warning after 60 secs. The redirection is aborted if the Alarm Clears before 60 seconds.
I will like an efficient query to check how many times it has been triggered as an alert without being escalated to a Warning.
Any Ideas on a Query for this?
  • SCADA
BevanWeiss
Spock BevanWeiss
Spock
Posted: ‎2019-11-29 04:21 AM
In response to sbeadle
1
2234
@sbeadle
another option might be to have a pair of Method Alarm Redirections.  The first executes immediately (0s delay) for the low severity only, and increments the value of an Internal Analog Point.  The second executes immediately for the Elevated severity only and decrements the value of the same Internal Analog Point.
It's definitely a bit of a cludge, but I think in regards to database efficiency it would be quite high.
  • alarm
  • counting
  • redirections
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2019-11-29 03:19 AM
2238
Hi Curious.
Naturally you can search the event log, and if this is for occasional viewing and reporting it might be the best.
If you want 'live' counting for individual alarms then it could be impractical, and you might want to consider using Logic or Calculation points. Both can be triggered off alarm transitions and count to a point.
BevanWeiss
Spock BevanWeiss
Spock
1
2235
@sbeadle
  • alarm
  • counting
  • redirections
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2019-11-29 04:57 AM
In response to BevanWeiss
Nice idea!
