Trend Scaling issues in Webx
Showing results forΒ
Did you mean:Β
  • Remote Operations
  • Trend Scaling issues in Webx
sbeadle
Kirk sbeadle Kirk
323
AndrewScott
Admiral AndrewScott
118
BevanWeiss
Spock BevanWeiss
100
  • Remote Operations Forum
EcoStruxureβ„’ Geo SCADA Expert
tkswathik
Lieutenant JG tkswathik
Lieutenant JG
Posted: β€Ž2020-08-11 07:06 PM . Last Modified: β€Ž2023-05-03 12:12 AM
4002
Does the IIS based webx in 2017 r3 not support scaling of y-axis?. We are using the IIS based website on 2017 R3 (july 2019) and dont get this option on any type of trends.  Has anyone had this issue before ?
  • WebX
BevanWeiss
Spock BevanWeiss
Spock
Posted: β€Ž2020-08-11 09:35 PM . Last Modified: β€Ž2020-08-11 09:36 PM
6
3991
I would probably not invest heavily in the 'IIS WebX' environment.
With GeoSCADA Expert there is a new 'web-based' platform in the form of Virtual ViewX.  From the help documentation (the absence of topics around IIS WebX), it appears that the 'IIS WebX' is largely being left by the way-side.
The 'Original WebX' is still where the scripting / XML interaction is based, so it will stay around for a while, but 'IIS WebX' was really just a layer over this, and it never did quite reach the level of maturity that was required of it.
Hopefully one of the Schneider people will say that I'm wrong on this, and that your Trends will work beautifully if you tick a box.  But my recommendation would be to revert to the Original WebX in the interim, and investigate whether migrating forward to Virtual ViewX may be the more appropriate solution longer term.
Virtual ViewX definitely provides a much better user experience than either the Original WebX or the IIS WebX.  Although it does have some additional administrative considerations.
That aside, it does appear that the November 2019 update did have this associated with it:
[SUP-11074] Changed New WebX under IE to use ActiveX to display trends for Trend database objects
But you'd have to note that this means you'd need to use IE as the web browser, and retain support for ActiveX controls.
tkswathik
Lieutenant JG
Posted: β€Ž2020-08-11 11:06 PM
In response to BevanWeiss
3984
@BevanWeiss thanks for the reply.
I Tried exploring the virtual viewx but looking at the hardware requirements I feel it might be very resource intensive. So reverting to original webx might be better and easy in the interim
BevanWeiss
Spock BevanWeiss
Spock
Posted: β€Ž2020-08-12 06:27 PM
In response to tkswathik
3952
RemoteApp is built on RDP.  The RemoteApp mechanism is what I would recommend.
They would then launch a full features ViewX client via the RemoteApp.  But since it's RemoteApp, they do not need to have a Windows OS locally.  The ViewX itself is run remotely (on the Microsoft RDS Session Host).
Replies 7
BevanWeiss
Spock BevanWeiss
Spock
6
3992
tkswathik
Lieutenant JG
3985
BevanWeiss
Spock BevanWeiss
Spock
Posted: β€Ž2020-08-11 11:25 PM
3980
Depending on what the end-user devices are, we've had reasonable success with Microsoft RDP.
I believe there are applications for both Android and iOS devices which provide native support for RDP sessions (and hence likely work well with the RDWeb 'stuff').
If you have more constrained HTML5 only type of devices (like locked down thin-clients), then this wouldn't be an option, but unfortunately neither would the Original WebX (since it requires ActiveX controls).
tkswathik
Lieutenant JG
Posted: β€Ž2020-08-12 07:33 AM
3963
By using Microsoft RDP, do users have to remote into some server in your environment and then run IE on it? We are using Microsoft RemoteApp as we have external users needing access to their data hosted in our environment.
BevanWeiss
Spock BevanWeiss
Spock
3953
tkswathik
Lieutenant JG
Posted: β€Ž2020-08-17 02:37 PM
3899
Thank you !!
I am working on publishing ViewX on RemoteApp, but ran into a different issue it might be better if it is a separate post.
BevanWeiss
Spock BevanWeiss
Spock
Posted: β€Ž2020-08-17 10:27 PM
Yes please, keeping threads separate for separate issues is very much appreciated.  The search on this forum struggles enough as it is πŸ˜›
Β
