Template expressions, OPC tag setup
  • Remote Operations
  • Template expressions, OPC tag setup
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
116
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
clivebe
Crewman clivebe
Crewman
Posted: ‎2025-01-21 12:29 PM
1030
Hi looking for some advice (or point me in right direction), new to GeoScada and my application is Omron NX PLC <-> Kepserver OPC to Geoscada. Have standard AIOs in plc and building templates with a parameter deviceID to reference the PLC UDT. Sort of have it working trying 1 tag with the attached expression.
My question, is this the right way to go?, is there any info on the write format for the expressions.
Also is there a way to disable the control VQT popup when writing to a tag?
thanks in advance,
Clive
  • SCADA
  • ViewX
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2025-02-06 02:27 AM
957
I don't know of any best practice for writing expressions.
You can use Name and FullName in expressions to derive settings from the name of the instance.
You are likely using the default pick menu action - you can control pick actions more specifically using a method pick action and/or pick action menu.
sbeadle
Kirk sbeadle Kirk
Kirk
958
clivebe
Crewman clivebe
Crewman
Posted: ‎2025-02-06 09:11 PM
In response to sbeadle
1
930
Thanks Steve,
also.. BIG thanks for your help videos, please don't go anywhere for 6 months until project completion haha,
 cheers
Clive
clivebe
Crewman clivebe
Crewman
Posted: ‎2025-03-07 01:08 AM
In response to clivebe
Righto got my head around the addressing and property scripting, not dissimilar to Ignition etc, just hidden a bit.
For anyone else reading this add the parameters u want in the template happy days
