Telemetry Signal Format
  • Remote Operations
  • Telemetry Signal Format
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
116
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
abdullah123456789
Lt. Commander abdullah123456789
Lt. Commander
Posted: ‎2022-07-25 01:23 PM . Last Modified: ‎2023-05-02 11:54 PM
1458
Hi everybody,
I created Telemetry Signal List in Geo Scada Expert 2021. When I export the signal list and open it with Notepad, I see the yellow quotation marks in the image below.
But I need to export all data like below image. (Quotation marks must only be before and after values)
I'm adding the SQL query I used below;
SELECT
"His15MAvg"."RecordTime" AS " CurrentTime", "WLM_ID", "His15MAvg"."Value" AS "CurrentValueAsReal", "His15MAvg"."Quality"
FROM
"HistoricView"."His15MAvg" AS "His15MAvg" INNER JOIN CDBPOINT ON "His15MAvg".ID = CDBPOINT.ID
WHERE
"WLM_ID" = '2190528_LE-15-44-Omerli_Art_24000_Depo_Su_Seviye' AND "His15MAvg"."RecordTime" BETWEEN TIMESTAMP '2022-01-01 00:00:00' AND TIMESTAMP '2022-07-20 23:00:00'
  • SCADA
  • Telemetry
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
Replies 5
BevanWeiss
Spock BevanWeiss
Spock
Posted: ‎2022-07-25 08:06 PM
1444
How are you 'exporting' this data?
Provide screenshots of the configuration of the object that you're using for this.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
abdullah123456789
Lt. Commander
Posted: ‎2022-07-25 11:45 PM
In response to BevanWeiss
1421
I'm using 'SQL Export Module' and sharing SQL query screen.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2022-07-26 04:12 AM
In response to abdullah123456789
1404
Your output image has extra quotes wrapping entire lines of the output, then causing inner quotes to be doubled.
But I just tested this myself and I don't see it, even by using the Swedish locale and selecting Comma Separated.
CurrentTime,FullName,CurrentValueAsReal,Quality
2022-07-26 11:00:00.000,Test.New Analog Point,"3,24",524480
2022-07-26 11:15:00.000,Test.New Analog Point,,2097152
2022-07-26 11:30:00.000,Test.New Analog Point,,1075838976
2022-07-26 11:45:00.000,Test.New Analog Point,,1075838976
Has the output file been modified by another tool?
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
abdullah123456789
Lt. Commander
Posted: ‎2022-07-26 06:01 AM
In response to sbeadle
1397
No, i didnt use another tool. The data I exported is in historic type, not current datas. I view the signal list wit Excel properly, but when i view the signal list with Notepad ++  i encounter this problem. Because of i need to know if the data type is string or not string.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2022-07-26 07:45 AM
Somehow each record has acquired additional quotation marks. Perhaps try setting the export to tab-separated?
You may need to contact the support team.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
