Suggestion: Video Integration
Showing results forΒ
Did you mean:Β
  • Remote Operations
  • Suggestion: Video Integration
sbeadle
Kirk sbeadle Kirk
323
AndrewScott
Admiral AndrewScott
118
BevanWeiss
Spock BevanWeiss
100
  • Remote Operations Forum
EcoStruxureβ„’ Geo SCADA Expert
MikeForshock
Lieutenant JG MikeForshock
Lieutenant JG
Posted: β€Ž2020-04-16 02:36 PM . Last Modified: β€Ž2023-05-03 12:15 AM
4857
In some previous (legacy) platforms we had the ability to embedded video (RTSP, HTML) typically though the old OLE/ActiveX platform.
We have used the Remote Image option to update snapshots on a specific interval or action, but a live video option would certainly be a great addition for some applications. With the new HTML5 Virtual Client now part of 2019, maybe progress will be made to implement a HTML5 Video element that can use the codecs available on the machine.
Just a simple request or suggestion, for now we launch a dedicated VMS viewer.
  • Mimics
  • SCADA
  • Scripting
MikeForshock
Lieutenant JG
Posted: β€Ž2022-01-25 11:22 AM
2529
Chrome/WebKit is now used for the internal web page viewer as of version 2021.
Cannot do a download function, but most other functions appear to work (new window, responsive layouts).
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
Replies 10
Posted: β€Ž2020-04-16 08:00 PM
4848
You can open hyperlinks to web pages in ViewX, so if the video is on a page already it should work.
MikeForshock
Lieutenant JG
Posted: β€Ž2020-05-14 06:17 AM
In response to Anonymous user
Correct, you can force the default browser to open. We do this often to load external reporting and video connections
I am hoping more along the lines of embedding actual video in the mimic.
Posted: β€Ž2020-08-10 11:55 PM
4598
@Anonymous user thanks for sharing your thoughts .its working
BevanWeiss
Spock BevanWeiss
Spock
Posted: β€Ž2020-08-12 06:28 PM
Having an embedded video player within ViewX would still be good though πŸ˜‰
MikeForshock
Lieutenant JG
Posted: β€Ž2020-08-18 11:12 AM
4542
Since it appears Chromium/WebKit (Chrome, Edge (New), Operara, etc.) will now rule the world why not join the party with the integrated viewer:
Chromium Embedded Framework.
https://bitbucket.org/chromiumembedded/
Has links to using with .Net, Delphi, Java and others.
Allows embedding the web browser similar to how the ViewX currently embeds the IE ActiveX control.
A little bit of work and can keep security going.
Nearly every VMS and other machine vision camera works well inside a browser.
Allow a Inset window with the ViewX instead of only allowing a new or navigate and this will be easy to begin integration.
BevanWeiss
Spock BevanWeiss
Spock
Posted: β€Ž2020-08-18 03:56 PM
In response to MikeForshock
1
4535
Hi @MikeForshock
I'm not sure that ViewX has ActiveX anymore.  I know that it did have it (albeit unsupported) back in 2013 era (and prior), but I'm pretty sure when they migrated up to the 2014/2015 platform and had the major UI revamp it was dropped completely.
ViewX does actually already have a Chromium component, it's used to popout the GeoSpatial maps.  But these also aren't capable of being embedded into a ViewX Mimic at this stage (although I've got a few feature requests that I've submitted around this).
Definitely worth sending in feature request tickets in my opinion (to your local Tech Support contact).  Without feedback from End Users / System Integrators on what direction the product 'should' take, it becomes a guessing game for Schneider/AVEVA.
MikeForshock
Lieutenant JG
Posted: β€Ž2020-08-18 04:01 PM
In response to BevanWeiss
Interesting they would have Chromium support for the Geo/Maps but use the old OLE/ActiveX web component for displaying hyperlinks in ViewX:
HTTP USER AGENT: Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.2; WOW64; Trident/7.0; .NET4.0C; .NET4.0E; .NET CLR 2.0.50727; .NET CLR 3.0.30729; .NET CLR 3.5.30729; Tablet PC 2.0)
I am aware they no longer allow ActiveX integration within the ViewX and dont want that back haha.
MikeForshock
Lieutenant JG
2530
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
BevanWeiss
Spock BevanWeiss
Spock
Posted: β€Ž2022-01-25 10:10 PM
2520
It can't be nested within a normal Mimic display though right? (I've got 2021 installed, but haven't used it much).
If it supported a nested HTML 'viewer' (i.e. a display element on a standard Mimic that could be set with a URL) that would be great...
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: β€Ž2022-01-26 02:15 AM
No Bevan, though that has been lodged as an enhancement request.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
Β
