Splash Screen Modification
  • Remote Operations
  • Splash Screen Modification
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
116
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
relianttech
Ensign relianttech
Ensign
Posted: ‎2023-03-15 07:25 PM . Last Modified: ‎2023-05-02 11:47 PM
1272
Does anyone know where the GeoSCADA Splashscreen resides? I'd like to modify it or remove it to reduce load time.
I read an older article where you could modify the layout.xsl file under C:\Program Files\Schneider Electric\ClearSCADA\WWW\XSL and point to the new PNG file.  I did this and the old Splash Screen appears.
Thanks.
  • ViewX
  • Virtual ViewX
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
BevanWeiss
Spock BevanWeiss
Spock
Posted: ‎2023-03-15 09:36 PM
I think you're talking about different things here.
The XSL changes impacted on WebX.  Not ViewX.
But then you're mentioning GeoSCADA splashscreen, which I reckon you mean the ViewX splashscreen.  Not at all related to the XSL file.
There is no way that I'm aware of to safely modify the splash screen.  It's a resource associated with a DLL as I understand it.  So removing it will likely result in ViewX just crashing at startup.
JChamberlain1
Lieutenant JG JChamberlain1
Lieutenant JG
Posted: ‎2023-03-16 10:50 PM
I realllly doubt if you could remove the splash screen it would significantly reduce the load time.
ViewX already pre-loads 'something' on system startup.
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2023-03-17 02:13 AM
You are right Jesse. Removing the splash screen would not speed loading ViewX, it shows the splash while modules are being loaded in the background.
