Show or hide objects based on group membership
  • Remote Operations
  • Show or hide objects based on group membership
sbeadle
Kirk sbeadle Kirk
323
AndrewScott
Admiral AndrewScott
118
BevanWeiss
Spock BevanWeiss
100
  • Remote Operations Forum
AliG
Crewman AliG
Crewman
Posted: ‎2023-06-12 11:04 PM
1265
Hi there,
Dose somebody know how to enable/disable or show/hide an object (e.g. button) on GeoSCADA mimics based on the logged user group membership? I read previous similar threads but they weren't clear and I couldn't make this. Thanks
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2023-06-13 07:16 AM
[Moved from the Ideas list]
First, decide what privilege is to control visibility, such as Control. It depends on what the group members can do to that object or mimic. Then animate the visibility using the CheckAccess(privelige).
e,g: ".ValveAPoint.CheckAccess ('CTL')"
See:
https://tprojects.schneider-electric.com/GeoSCADAHelp/Geo%20SCADA%202022/Default.htm#ExpressionsGuid...
tfranklin
Commander tfranklin
Commander
Posted: ‎2023-06-19 06:35 AM
I'd run with what Steve suggested above if it's doable.  This method checks permissions for a user against a specific object which is what people would want to do the majority of the time.  If you have to check from the user group level then another option we've found, albeit likely heavier on the system, is to check for the username within the users a particular group returns.
I don't have it in front of me right now but I believe the syntax below is correct.
INSTRING(STR("Path.To.UserGroup.GetUsers()"),username()) > 0
