Security discrepancy between servers
  • Remote Operations
  • Security discrepancy between servers
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
116
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
PFISHER
Crewman PFISHER
Crewman
Posted: ‎2025-08-17 05:51 PM
615
Good morning,
I have an issue with displaying events without a user logged in that is affecting only one server of a primary/standby pair. (View x pointed to server 1, works fine, pointed to server 2 I get an error).
The issue is definitly security related ('qeury is malformed or invalid') when no user is logged in 'Guest'. AS soon as I log on the query runs fine.
Query is just vanilla select events.
SELECT TOP( 100000 )
"RecordId", "SeverityDesc" AS "~SeverityDesc", "RecordTime" AS "~RecordTime", "Source", "Message", "User", "Category", "Foreground", "SeqNo", "CommentNo"
FROM
CDBEVENTJOURNAL
WHERE
( "~RecordTime" BETWEEN { OPC 'H-23H' } AND { OPC 'H+1H' } )
ORDER BY
"~RecordTime" DESC, "SeqNo" DESC, "CommentNo" ASC
I have checked the following security settings -
Server Configuration\ System Configuration\Security: Tripple checked security settings are identical between the two servers.
Server Configuration\ System Configuration\Permission Restrictions: Tripple checked security settings are identical between the two servers.
View x (on servers) edit properties\ guest user \ event list range (same on both servers).
View x (on servers) edit security\ guest user \ event list range (same on both servers).
What other settings should I be looking for? (There is no AD integration on this setup - all local accounts).
--On a sandbox server I just cant recreate the query failure even intentionally trying to remove perissions to see events - the query never fails - even with no guest permissions beyond 'Read'
Thanks for any help
  • SCADA
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
AdamWoodlandToo
Lt. Commander AdamWoodlandToo
Lt. Commander
Posted: ‎2025-08-18 03:06 PM
607
Check Server Configuration -> SQL Query Configuration -> Parameters -> Allow guest user to execute SQL
It is a relatively new setting and maybe different between servers
AdamWoodlandToo
Lt. Commander
608
PatrickFisher
PatrickFisher
Cadet
Posted: ‎2025-08-18 03:59 PM
In response to AdamWoodlandToo
Thanks Adam, first go! thank you!
AdamWoodlandToo
Lt. Commander
Posted: ‎2025-08-21 08:34 PM
Catches me out all the time on test systems where the first thing I do is give Everyone full control so I don't have to log in!
