Scriptting Error - GEO SCADA
  • Remote Operations
  • Scriptting Error - GEO SCADA
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
116
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
BGedco2022
Lt. Commander BGedco2022
Lt. Commander
Posted: ‎2022-06-09 02:44 AM . Last Modified: ‎2023-05-02 11:55 PM
1482
Suddenly, Script of mimic not running giving us the below message
what could be the cause? any hint!!
thanks in advance
  • Mimics
  • SCADA
  • Scripting
  • ViewX
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
AndrewScott
Admiral AndrewScott
Admiral
Posted: ‎2022-06-09 02:57 AM
You've not provided the script so we can't see what the script is doing when the error occurs. However, the "Historic update is outside writable time window" error means you've tried to log an event journal message, point historic data etc. which is too far in future or too far in the past.
The time windows are defined in the Server Configuration tool:
https://tprojects.schneider-electric.com/GeoSCADAHelp/Geo%20SCADA%202020/Default.htm#ServerAdministr...
Andrew Scott, R&D Principal Technologist, AVEVA
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
BevanWeiss
Spock BevanWeiss
Spock
Posted: ‎2022-06-09 09:18 PM
1434
This is almost certainly because you have configured an 'Archive After' time that is shorter than the time range that you are trying to change.
Archive means store away as an exact replica of the original data.  By virtue this means that the original data must now be locked exactly as it is, no modifications or additions to the period that is 'Archived'.
So:
a. Ensure your actual online historic timeframe is longer than your time to modification
b. Ensure your Archive After timeframe is also longer than your time to modification (i.e. if you want to write data that was 1year ago, you need to have an Archive After set to > 1year)
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
AndrewScott
Admiral AndrewScott
Admiral
Posted: ‎2022-06-10 03:36 AM
In response to BevanWeiss
Archiving is really a legacy feature from the 1990's / early 2000's when hard disks were small / expensive and it was necessary to move historic data to offline storage (typically optical disks: CD or DVD) for long term storage. These days archiving is redundant  and all the historic data can just be kept online. Also, servers usually aren't even fitted with optical disk drives these days, although USB thumb drives could provide an alternative for offline storage.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
