Invalid web server request in GEO SCADA Log
  • Remote Operations
  • Invalid web server request in GEO SCADA Log
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
116
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
BGedco2022
Lt. Commander BGedco2022
Lt. Commander
Posted: ‎2022-06-12 01:39 AM . Last Modified: ‎2023-05-02 11:55 PM
1327
Hello All,
almost every minute this message registered in the events journal of GEO SCADA
Invalid web server request 'Requested version (3.0) is lower than we support (3.1)', received from client address x.x.x.x
what could be the cause? and how to solve it.?
thanks in advance
  • SCADA
  • ViewX
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
BevanWeiss
Spock BevanWeiss
Spock
Posted: ‎2022-06-12 08:44 PM
It seems pretty straight forward as to what could cause it...
The version of the web API being requested by the client at x.x.x.x (v3.0) is lower than the server supported version of the web API (v3.1).
I suspect that whatever client is connecting via x.x.x.x is running an out of date version of the web client, or is otherwise performing a request for a web API version that is no longer supported by the server.
You should upgrade the client to use a supported version of the web API (>=v3.1 it would seem).
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
AndrewScott
Admiral AndrewScott
Admiral
Posted: ‎2022-06-13 01:47 AM
The numbers in the error message are SSL versions - the minimum version supported by the Geo SCADA Expert web server is TLS 1.0 (aka version 3.1), however this can be configured to a higher minimum version, see https://tprojects.schneider-electric.com/GeoSCADAHelp/Geo%20SCADA%202020/Default.htm#SecurityGuide/D...
The following blog has some background on SSL versions:
https://www.globalsign.com/en/blog/ssl-vs-tls-difference
The client application needs to be updated to a minimum of TLS 1.0 to fix this issue.
Andrew Scott, R&D Principal Technologist, AVEVA
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
