ST Logic Program Not Initialising SQL Variable
  • Remote Operations
  • ST Logic Program Not Initialising SQL Variable
sbeadle
Kirk sbeadle Kirk
323
AndrewScott
Admiral AndrewScott
118
BevanWeiss
Spock BevanWeiss
100
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
MikeSI
Ensign MikeSI
Ensign
Posted: ‎2024-11-22 05:27 PM
1059
Hi Everyone
I thought I had a pretty good understanding of ST execution but haven't been able to find the answer to this problem.
I have an ST Logic program which is set to '0s' interval time and is only executed manually from a pushbutton on a mimic (using .execute method on a pick action).
The ST program queries a Data Table, finds a particular value in the table, and then inserts a new record in the table using an INSERT query. This part works fine.
Where the problem starts is if the table is cleared. Clearing the table is done by another pushbutton.
It looks like my %S Variable doesn't update (or query fails on an empty table?) at the beginning of the program because the Tag1 variable remain the same from the last execution.
VAR
Tag1 AT %S(SELECT ........)
END_VAR
If the %S variable is failing or not updating, is there a way I can capture this in the Logic so that I can manually reset my variables to some default values?
This only seems to happen if I clear the whole Data Table. If I just delete some records it works fine.
Thanks.
  • Logic
  • SCADA
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
MikeSI
Ensign MikeSI
Ensign
Posted: ‎2024-11-28 05:10 PM
In response to AndrewScott
Thanks @AndrewScott . I did have a play around with the VAR NOCACHE because it seemed like the likely solution.
It turned out that when the table was empty the .Value parameter kept the last good value. To solve this I was able to use the .Valid flag to check if the record was 'null' and if it was I would manually set the value to a default number.
Thanks again for your suggestion.
AndrewScott
Admiral AndrewScott
Admiral
Posted: ‎2024-11-25 03:35 AM
1056
Have you tried declaring the variable NOCACHE?
See Using VAR NOCACHE to Prevent Cached Values Being Used in an ST Program in the help.
Andrew Scott, R&D Principal Technologist, AVEVA
MikeSI
Ensign MikeSI
Ensign
