SQL Query with Tag Reference in Embedded List
  • Remote Operations
  • SQL Query with Tag Reference in Embedded List
sbeadle
Kirk sbeadle Kirk
315
AndrewScott
Admiral AndrewScott
105
BevanWeiss
Spock BevanWeiss
95
AdamWoodlandToo
Lt. Commander AdamWoodlandToo
39
EcoStruxure™ Geo SCADA Expert
Posted: ‎2021-12-14 06:04 PM . Last Modified: ‎2023-05-02 11:59 PM
1441
Hi Experts,
I'm looking for adding direct tag reference inside SQL query used in Embedded Lists. The aim is to place the embedded list inside template and instances can have queries 'relative to its area'.
In the below embedded query WHERE condition, can I have a tag/variable reference which is relative? Something like CONCAT(%M(..FullName), '.%') which doesn't work.
SELECT TOP(100)
"RecordId", "SeverityDesc" AS "~SeverityDesc", "RecordTime" AS "~RecordTime", "Source", "Message", "User", "Category", "Foreground", "SeqNo", "CommentNo"
FROM
CDBEVENTJOURNAL
WHERE
"Source" LIKE CONCAT(%M(..FullName), '.%')
Thanks in advance,
Justin
  • SCADA
  • ViewX
  • Direct Variable
  • Indirect Variable
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • sql
  • Telemetry and SCADA
AdamWoodland
AdamWoodland Schneider Alumni (Retired)
Posted: ‎2021-12-14 07:13 PM . Last Modified: ‎2021-12-14 07:13 PM
1
1434
You'll need to do this in the animations not the Query tab, set the sql animation to:
'SELECT TOP(100) "RecordId", "SeverityDesc" AS "~SeverityDesc", "RecordTime" AS "~RecordTime", "Source", "Message", "User", "Category", "Foreground", "SeqNo", "CommentNo" FROM CDBEVENTJOURNAL WHERE "Source" LIKE ''' + "..FullName" + '.%'''
The ''' are three single quotes, two of which will be interpreted as a single quote as part of the SQL syntax, and the last quote will be ending the literal string
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
AdamWoodland
1
1435
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
Posted: ‎2021-12-14 07:48 PM
In response to AdamWoodland
Thanks Adam, that solved the problem.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
