Problem with trends
Select a Country
  • Remote Operations
  • Problem with trends
sbeadle
sbeadle Champion
335
AndrewScott
AndrewScott
125
BevanWeiss
BevanWeiss
103
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
Posted: ‎2021-12-27 05:15 AM . Last Modified: ‎2023-05-02 11:59 PM
2
1483
Problem with trends
Good day.
When i try to build a trend of an analog point (point value changes very slowly, 1 change in 1-2 days) and when i use ruler on my trend the current value shown as unidentified.
how can i fix this problem.
  • ViewX
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
BevanWeiss
BevanWeiss
Champion
Posted: ‎2021-12-27 08:30 PM
You might need to provide a screenshot of this.  It's not ringing any bells for me having seen it before.
If you could also tell us what configuration your trend line has (because I suspect when you send the screenshot it's going to say 'Processed Historic', so you should tell us what algorithm, resample interval etc you have configured).
If it's configured as a 'Raw Historic' and you don't have a sample within the time window being displayed, then I could somewhat understand this (although it would be nice if ViewX would display the closest data point available)..
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
geoffpatton
geoffpatton
Leader
Posted: ‎2022-01-03 06:46 AM
Usually when I have very little values going into history it is because I need to set the Significant Change on the Analog Point tab. I use Absolute and then whatever value is applicable. Sometimes the value that i need to use creates to many Historic records but it is desired for other things, so then I have to setup Compression on the Historic tab.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
