Pink color error in graphics.
  • Remote Operations
  • Pink color error in graphics.
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
116
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
MrBong
Ensign MrBong
Ensign
Posted: ‎2024-10-01 11:02 AM
1406
I restored the backup and graphics in pink color.
how to remove this error?
  • ViewX
  • ClearSCADA
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
  • ViewX
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2024-10-24 04:41 AM
Was Adam's suggestion the answer?
i.e. if you export config from location X.Y, and your configuration has relative references to items outside the export (e.g, references to A, A.B or X) then import into a different folder or level (e.g. C or D.E) then the import won't find these outside references.
It's best to name an SDE file by the full name of the group, then you know where to import it to. e.g. if you export "East.RTU.Points" group, then place your cursor on "East.RTU" and import to that parent in order to get back what you exported.
Replies 4
geoffpatton
Captain geoffpatton
Captain
Posted: ‎2024-10-03 07:14 AM
Pink indicates bad quality.
In this case the pink is indication bad animation references. The OPC Paths in the objects' animations are referring to something that does not exist. You also have value displays that say ***Error*** for the value so same thing. You also are missing one or more embedded mimics. The white box with a red X in it should be displaying an object.
If you restored this mimic in a different location than the one it originated in it is possible that the objects that your mimic is trying to reference could exist and you could correct the OPC Paths. The missing Embedded mimic could simply be something you drag and drop back in but if it requires some animations to be added to it to display its functionality then you'll have to figure that out.
Also any objects that have pick actions set on them are likely to need correcting.
MrBong
Ensign MrBong
Ensign
Posted: ‎2024-10-04 03:36 AM
Someone please help me with suggestion to how remove this error. Otherwise i have to develop again the whole backup.
geoffpatton
Captain geoffpatton
Captain
Posted: ‎2024-10-04 07:12 AM
You either have an incomplete backup that you imported (restored) and will have to recreate the missing objects, or you imported that graphic into the wrong location so all its references are bad and you need to import it in the correct location.
If you look at the animations of one or more of the pink objects you'll see the reference path it is expecting the object it is referencing to be, usually references to an object will also include a parameter of the database object something like "Station1.Pump1.Speed.CurrentValue where current value is the parameter. It is most likely that the Main 1 mimic is using relative references, which means the reference path is relative to the mimics location in the database, and not the absolute path from the root of the database.
If the objects actually exist in the database you should be able to go find where the really are and then be able to figure out where the Main 1 mimic backup should be imported.
Watch the YouTube videos on Geo SCADA and reference the Geo SCADA help so you can better understand how Geo SCADA works. https://community.se.com/t5/EcoStruxure-Geo-SCADA-Expert/YouTube-playlist-for-our-Ecostruxure-Geo-SC...
sbeadle
Kirk sbeadle Kirk
Kirk
