OPC Historic Tag , End Last ,Average Last
  • Remote Operations
  • OPC Historic Tag , End Last ,Average Last
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
116
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
Clearscada_EIT
Ensign Clearscada_EIT
Ensign
Posted: ‎2025-09-25 12:31 PM
1098
I have my watchdog tag that is counting up by 1 every minute.
I would like to retrieve the reading of this tag at 5 mins ago, and Average value of the past 5 minutes
For retrieving value at 5 min ago, i used this expression : ".WatchDog;End Last;M;-5M"
For retrieving average value for last 5 mins, I used this expression : ".WatchDog;Average Last;M-5M;1M"
However, both values that calculated in Geoscada are incorrect.  (screenshot)
Can someone help
  • SCADA
  • ViewX
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2025-10-30 02:56 AM
Taking a look at the expressions, I think they need adjustment:
I think this should be ".WatchDog;End Last;M-5M;1M"
I think this should be ".WatchDog;End Last;M-5M;5M"
The first parameter is the start of the window, the second is the length.
(End Last is slightly different from other aggregates, because if there's no sample in the window it looks back for the latest previous).
Steve
Replies 4
AndrewScott
Admiral AndrewScott
Admiral
Posted: ‎2025-09-26 01:52 AM
@Clearscada_EIT The screenshot doesn't show the raw historic data over which the calculations are being performed so I can't see what the problem might be.
Andrew Scott, R&D Principal Technologist, AVEVA
Clearscada_EIT
Ensign
Posted: ‎2025-09-26 06:07 AM
1057
 @AndrewScott Here is the screenshot of the raw historic data
Clearscada_EIT
Ensign
Posted: ‎2025-10-03 03:04 PM
In response to Clearscada_EIT
Hi@AndrewScott @sbeadle , not sure if you have any updates on this?
sbeadle
Kirk sbeadle Kirk
Kirk
Steve
