.NET API List Instance Configuration Properties
  • Remote Operations
  • .NET API List Instance Configuration Properties
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
116
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
LogicGateKeeper
Crewman LogicGateKeeper
Crewman
Posted: ‎2024-12-12 08:31 PM
721
I using the .NET API in C# and am trying to figure out a way of viewing all the configurable properties of a instance through the API rather than having to look at the ViewX client.
Cheers.
  • Scripting
LogicGateKeeper
Crewman
Posted: ‎2024-12-15 05:10 PM
Thanks, I have found a solution that works for me. Still using the simple namespace. You first get the class Definition of the DBOject, once you have that use the .ConfigurationProperties to list the config Properties. What caught me up is that I needed to iterate through all the Base Classes to see all the inherited properties aswell.
Here is an Example:
var currentClass = StationTest.ClassDefinition;
while (currentClass != null)
Console.WriteLine($"Class: {currentClass.DisplayName}");
foreach (var property in currentClass.ConfigurationProperties)
Console.WriteLine($" Config Property: {property.Name}");
foreach (var property in currentClass.DataProperties)
Console.WriteLine($" Data Property: {property.Name}");
foreach (var property in currentClass.DynamicProperties)
Console.WriteLine($" Dynamic Property: {property.Name}");
currentClass = currentClass.BaseClass;
AdamWoodlandToo
Lt. Commander AdamWoodlandToo
Lt. Commander
Posted: ‎2024-12-15 03:28 PM . Last Modified: ‎2024-12-15 03:28 PM
Not aware of anything in the API, might well be something the Advanced bit though.
You could parse the schema for the properties, its XML but you'd need to follow it up the tree to get all the relevant properties.
LogicGateKeeper
Crewman
Here is an Example:
