List object on Mimic
  • Remote Operations
  • List object on Mimic
sbeadle
Kirk sbeadle Kirk
323
AndrewScott
Admiral AndrewScott
118
BevanWeiss
Spock BevanWeiss
100
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
Posted: ‎2021-05-13 11:00 PM . Last Modified: ‎2023-05-03 12:03 AM
1666
I have an embedded list on mimc, wich shows links to Default view of the plants. Is it possible to open this links in new tab? Is it possible to link some controls to other tabs (for example - show position on map)? And is it possible to disable context menu, wich shows on click to list?
  • Mimics
  • ViewX
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2021-05-17 07:48 AM . Last Modified: ‎2021-05-17 07:54 AM
Yes, you can add your own scripted menu to replace the standard object/list pick menus. Use the pick action wizard to attach a vbscript in the mimic to the list.
Your vbscript can determine the row information for the row which was clicked, so it can go to the correct destination. Script can build a popup menu of different items.
This script shows the properties available when you click a list:
sub ListClick1
	MsgBox "Clicked:" & vbCRLF _
	& "CurrentColIdx = " & Mimic.Layers("New Layer").Item("Lst_1").CurrentColIdx & vbCRLF _
	& "CurrentRowIdx = " & Mimic.Layers("New Layer").Item("Lst_1").CurrentRowIdx & vbCRLF _
	& "CurrentRowId = " & Mimic.Layers("New Layer").Item("Lst_1").CurrentRowId & vbCRLF _
	& "CurrentRowName = " & Mimic.Layers("New Layer").Item("Lst_1").CurrentRowName & vbCRLF _
	& "Current1stColDataStr = " & Mimic.Layers("New Layer").Item("Lst_1").Current1stColDataStr & vbCRLF _
	& "Current1stColDataInt = " & Mimic.Layers("New Layer").Item("Lst_1").Current1stColDataInt
end sub
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
sbeadle
Kirk sbeadle Kirk
Kirk
sub ListClick1
end sub
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
