Is it possible to use a sql query in ST Logic to access data in linked odbc table with 64bit driver?
  • Remote Operations
  • Is it possible to use a sql query in ST Logic to access data in linked odbc table with 64bit driver?
sbeadle
Kirk sbeadle Kirk
323
AndrewScott
Admiral AndrewScott
118
BevanWeiss
Spock BevanWeiss
100
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
RoyL
Crewman RoyL
Crewman
Posted: ‎2020-02-05 02:30 AM . Last Modified: ‎2023-05-03 12:18 AM
4615
When I execute a ST Logic with a sql query to a linked odbc table with a 64bit driver, I get the following program error:
QP Error - Cannot suspend Database Write Lock lock while caching the results of SQL queries for OnUpdate execution
How can I fix this error?
Posted: ‎2020-02-05 03:46 PM
In response to RoyL
1
4601
I can see one similar issue raised before, and on that occasion it was resolved by 'adding the NOCACHE attribute to the VAR ... END_VAR block that contains the query.'.  Is NOCACHE defined?
Replies 6
MikaelKrantz
Guinan MikaelKrantz Guinan
Guinan
Posted: ‎2020-02-05 03:45 AM
4611
What type of system are you asking about?
RoyL
Crewman RoyL
Crewman
Posted: ‎2020-02-05 04:06 AM
In response to MikaelKrantz
4609
OS: Windows Server 2016 (64bit)
ClearScada: CS2017 R3
ODBC DSN: 64bit
When I run the query in an eventwindow or mimic script I get the data (no error),
when I try to execute a ST Logic with the same query I get the error
In response to RoyL
1
4602
BevanWeiss
Spock BevanWeiss
Spock
Posted: ‎2020-02-05 04:12 PM
1
4591
Using an Linked ODBC Table in an ST query is a really bad idea.  I would recommend that you try to look at an alternative method of getting this data into your ClearSCADA system if at all possible.
The additional performance (and availability) issues around the Linked ODBC table will result in issues with Database Locks which will affect your entire ClearSCADA system.
You could possibly do a push from an SSIS package or similar (if using MSSQL) into a ClearSCADA DataTable, so that the ST SQL query is referencing a native ClearSCADA Table.
  • Linked Tables
  • sql
  • ST
RoyL
Crewman RoyL
Crewman
Posted: ‎2020-02-05 10:55 PM
In response to BevanWeiss
Hi BevanWeiss,
Thanks for your recommendation!
RoyL
Crewman RoyL
Crewman
Posted: ‎2020-02-05 10:58 PM
In response to Anonymous user
Hi HowardF,
This was the trick!
Thanks for your solution!
